wep-shared-key-auth
Profile Config Commands
Enables support for 802.11 WEP shared key authentication
When enabled, devices, using this profile, use a WEP key to access the network. The controller or service platform use the key algorithm to convert an ASCII string to the same hexadecimal number. Clients without the recommended adapters need to use WEP keys manually configured as hexadecimal numbers. This option is disabled by default.
Syntax
wep-shared-key-auth
Parameters
None
nx9500-6C8809(config-profile-TestNX5500)#wep-shared-key-auth
nx9500-6C8809(config-profile-TestNX5500)#show context
profile nx5500 TestNX5500
 bridge vlan 1
  bridging-mode isolated-tunnel
  ip igmp snooping
  ip igmp snooping querier
 wep-shared-key-auth
 autoinstall configuration
 autoinstall firmware
 crypto ikev1 policy ikev1-default
  isakmp-proposal default encryption aes-256 group 2 hash sha
 crypto ikev2 policy ikev2-default
 crypto ipsec transform-set default esp-aes-256 esp-sha-hmac
 crypto ikev1 remote-vpn
 crypto ikev2 remote-vpn
 crypto auto-ipsec-secure
 interface me1
 interface ge1
  ip dhcp trust
  qos trust dscp
  qos trust 802.1p
 interface ge2
  ip dhcp trust
--More--
Related Commands
no Disables support for 802.11 WEP shared key authentication
